ive just been out for a blast and i jumpped on the motorway opened it up and all i got was fartttttttttttttttttttttttt but didnt go any faster i did sort the choke out last week as it was stuck on and that seamed to do the trick had a look again and its ok any ideas ?
Did you get hold of Luke about that cherry picker?
Thanks for the engine stand too. It`s bloody great! I`ve already tripped over it in the garage, bashed me leg good & proper!
Why don`t you sell `em in classifieds?
IF the problem is purely jetting and it wont pull it's a lot wrong, like 4 or 5 sizes wrong.
Mine (forget the numbers, it's a '28 ) runs 182-188 right now and is pretty much spot on for a safe summer base. It's was also useable but soggy 188-192 and if jetted on the day for a hot TD/race would probably end up around 178 or so.
That's a big range where it runs alright, it's also run std pipes, airbox and various intake mods anywhere in that range and always been OK. Not very crisp around 190 and not very safe around 180 but not far enough out to not work.
If your certain it's setup drop it down a size and see if it's better, or if you're scared, go up a size, see if it gets worse, just write it all down, air temp, jets, other mods, how it went etc. then you'll get a feel for what's what. _________________ Please do not PM me technical questions, if you can't find it on the Forum start a thread
I'll do my best to get that stuff over to you asap, then you can try the jetting. _________________ If you dont like the way that i ride.....Stop trying to keep up!!!!!
Do you need some standard jets etc as I'll bring my spare set of carbs if you do.
What else was there, apart from exhausts I'm sure there was something. _________________ If you dont like the way that i ride.....Stop trying to keep up!!!!!
No worries, is it just the standard cans you need or the chambers too. If you dont need the chambers I may even pop over on the bike. _________________ If you dont like the way that i ride.....Stop trying to keep up!!!!!
Will do, anyone else in the northwest fancy a ride out next weekend (weather permitting. ) _________________ If you dont like the way that i ride.....Stop trying to keep up!!!!!
