hi all. just been out on my 300 been running fine inmid range 8/10000ish but when used to max 12000ish after a few minutes the engine slowsand wont really rev after another minute or so its ok again but if used hard repeats itself again. havent looked at anything yet but on arival home everything seems ok,ie rev up ok no noises etc. any help appreciated thanks
Blocked tank filter? Knackered hose from tank to carbs? Blocked vent for air to get into tank as fuel drains out? _________________ MC21SP Plaything
just checked tank breather,fuel filter and line all seems ok.had a new air filter earlier this year also float hieghts were checked ok.cant help but think that its running rich [210] main jets no power jet,although its oatmeal colour when plug chopped.what you think.thanks sofar
i had a similar problem on an 18 where when i put the tank back on i tristed the fuel hose. it ran fine till it needed fuel for any period of time. _________________ 94 mc28 SE
Check to see you have full, unrestricted flow of fuel to your carbs when the fuel valve is open (turn the valve on and visually check there is free flow at the end of the line to the carbs). You could have a restriction in your fuel petcock, line, or tank filter. _________________ Paul Herr
'88 FZR4/GSXR/YZF Frankenbike
MY BIKE PICS
Yep I think its fuel too. I went out yesterday with my new body work ( which looks SWEET thanks TYGA ) Anyway the tank that came with had a little crap in it that I tried many methods to remove and while I got most I don't think I got it all. My bike was doing the same and then it got really bad and I switched to reserve and it was back to just a little sputtering. Sorry for the novel but yeah I think we both have a fuel problem. _________________ 1995 A kit TZ 250
1994 Rothmans NSR 300sp SOLD
fstnsr wrote:i had a similar problem on an 18 where when i put the tank back on i tristed the fuel hose. it ran fine till it needed fuel for any period of time.
Come tho think of it I did a similar thing on my GSXR many years ago. When I put the tank back on after a service I pinched the vent hose for the carbs and it wouldn't run right. Cost me a race and took a while to figure out. _________________ james
MC21 Rothmans
RS250
RC31
CRF250X
748R
Porsche (many)
are you using quick release valves between the carb and tank ?
I had a similar problem, the release was tight, but didn't flow enough fuel. A reconnect, making sure it seated, solved my problem. _________________ Poul
MC21SE, KISS box
MC21SP, HRC box, racing loom
