Rothmans tank paint measurements Q (with photos)
demetris74
Fri Dec 01, 2006 7:23 am » Post: #1 » Download Post
Guys i want the measurements of the rothmans paint scheme on the MC21 tank i have some photos attached showing with red arrows of the measurements i need.
who ever is kind enough to measure his rothmans tank and give me that specific distances i would be really happy. i tried to find out roughly from photos but is difficult.
Thanks a lot
James
mick
Fri Dec 01, 2006 9:47 am » Post: #2 » Download Post
I can do mine but it's not the standard Rothmans scheme.
And I cant see any pics. Wink Rolling Eyes
demetris74
Fri Dec 01, 2006 12:19 pm » Post: #3 » Download Post
Mick
is it mesured correctly? if it is then i am ok with it.
from the photo it looks as its ok
James
mick
Fri Dec 01, 2006 12:29 pm » Post: #4 » Download Post
OK what do you need measuring
demetris74
Fri Dec 01, 2006 2:07 pm » Post: #5 » Download Post
Knowing the distance to seperate the blue paint cause mine is the red white tank that the seperation of red is higher, i need the measurement if you can please
James
j911brick
Fri Dec 01, 2006 5:54 pm » Post: #6 » Download Post
Did you buy the correct decals, or are you going to paint the stripes?
james
MC21 Rothmans
RS250
RC31
CRF250X
748R
Porsche (many)
mick
Fri Dec 01, 2006 10:10 pm » Post: #7 » Download Post
demetris74 wrote:Knowing the distance to seperate the blue paint cause mine is the red white tank that the seperation of red is higher, i need the measurement if you can please
James
Can you explain a little better?
demetris74
Sun Dec 03, 2006 3:22 pm » Post: #8 » Download Post
from the photos i send i want the distance from bottom of tank to lower blue, measurment round the edges and front check the photos i attached
thanks for the help
mick
Sun Dec 03, 2006 5:32 pm » Post: #9 » Download Post
demetris74 wrote:from the photos i send i want the distance from bottom of tank to lower blue, measurment round the edges and front check the photos i attached
thanks for the help
I would if i could see any photos.
Sun Dec 03, 2006 11:41 pm » Post: #10 » Download Post
Try this Mick...
Measure the distance at the two arrows, then measure the thickness of each stripe. That should do it.
demetris74
Mon Dec 04, 2006 6:40 am » Post: #11 » Download Post
Thanks Andy
Thats exactly what i need, i will add the stripes later, first of all i need the distanse as Andy showed. to seperate and paint the tank
Laughing
Thanks for the addition Andy i guess mine was not so clear.
James
mick
Mon Dec 04, 2006 9:01 am » Post: #12 » Download Post
No worries I'll do it tonight when I get in for you.
demetris74
Mon Dec 04, 2006 9:36 am » Post: #13 » Download Post
Thanks Mick
Apreciate it man, just give me the measurements on the sides rear of tank and front sides where the blue line starts. will paint the bluew and then add the stripes therefore give me measure starting from the lower blue under the stripes.
James
mick
Mon Dec 04, 2006 8:46 pm » Post: #14 » Download Post
Right here we go.
From the bottom of the tank seam the bottom of the blue stripe is 125mm
The 1st stripe is 12mm
The 2 Golds and the Red are 8mm and the white gaps between are 5mm
(this is the nearest I could work out with the sh*t tape measure I was using)
Hope this helps.
Mick
demetris74
Tue Dec 05, 2006 6:12 am » Post: #15 » Download Post
Thanks mick that will do i think
i don't mind accuaracy just to be close enough
Thanks again mate
James
