Okay Gents, just wondering...appears I have issues w/PGM as there is no power to Servo, can I manually set Servo to High position, and run the bike? Inquiring minds want to know!
Cheers _________________ FILOLI - Fight, Love, Live
The TPS doesn't have to be adjusted. If you want to run the power valves full open all you have to do is (with the ign turned off) move teh servo by hand into the high position. I would also disconnect the servo from the harness. _________________ If I have to take the carbs off once more...
If I adjust manually the servo to high, will there be any differences in performance, from low to mid and high end ? _________________ FILOLI - Fight, Love, Live
It will have no bottom end power, alittle mid range power and the same top end power. It seems the best results are gained from having the valve just shy of fully open. This gives pretty good top end but with alittle of the mid range retained. _________________ If I have to take the carbs off once more...
Like he says, ensure you unplug it from the harness, or you may find the PGM goes POP in very quick time.
The servo draws big current, and is the biggest known killer of PGM's. _________________ MC21SP Plaything
