MC28 motor into a MC21, easy or not?
wtf?
Mon Dec 18, 2006 3:32 am » Post: #1 » Download Post
Gidday Guys,
Ive got an MC21 that has had big end bearing seize/disintegrate with the resulting mess hurting bores/pistons/crank bearings etc
I have found a replacement MC28 engine which, I think, will be cheaper to put in than repair the one I have.
Before I buy it, could anyone please tell me if its just a straight forward swap, or have I got some work to do with different electrical connectors/carb rubbers/powervalve connections etc?
Any advice or comments would be appreciated.
Thanks very much
Richard
Tauranga, New Zealand
fenton
1990 Honda NSR250 MC21
Mon Dec 18, 2006 10:37 am » Post: #2 » Download Post
its a straight swap as far as i know but the flywheel has less advance than the 21 flywheel but you can change that over from your old engine i think there are some other small differences but not to sure on what they are
Mon Dec 18, 2006 10:57 am » Post: #3 » Download Post
You will also need to swap the gear postion sensors over and the inlet manifolds.
Mon Dec 18, 2006 11:02 am » Post: #4 » Download Post
And brace yourself for '28 power Laughing
