NSR300 sort of ready 'ish
Page 2 of 3  Goto page Previous  1, 2, 3  Next Download Topic
Matt@TYGA
Supporter - Vendor
Supporter - Vendor
Thu Jan 04, 2007 10:32 am » Post: #16 » Download Post
I have modified my VHM heads, and am doing another two sets now for two other 300 engines I'm building.
They are of course NSR150 VHM heads but for the front head to work properly we must change the spigot position.
If the heads are ordered for the 300 kit (not for the NSR150SP), then the heads will be supplied ready to bolt on, with the insert that I've got fitted now, which is for 95ULG. Throttle response is instant and power is immense.
Other inserts that VHM have machined for me are for 100LL avgas, 108 oct. ULG race fuel and we're now designing for VP C-16. They'll make any insert I want if I ask them nicely Cool
I'll post the weights and comparisons up tomorrow.
maxim
Thu Jan 04, 2007 10:53 am » Post: #17 » Download Post
I use Shell 98... Is there one for that?
Matt@TYGA
Supporter - Vendor
Supporter - Vendor
Thu Jan 04, 2007 11:14 am » Post: #18 » Download Post
As I said, they'll make me any head insert I want.
The insert volume I'll use on the 300 kit isn't fixed in stone yet as I'll be able to have a play on the dyno.
I've got 98 ULG fuel here too if needed, so I can give that a run up to get a base.
maxim
Thu Jan 04, 2007 1:12 pm » Post: #19 » Download Post
Nice. And looking forward to those piston weights... Never been too happy with the extra mass on the 300 kit pistons purely for crank/rod kindness, so I'd be right on your tail for some lightweight ones!
Matt@TYGA
Supporter - Vendor
Supporter - Vendor
Thu Jan 04, 2007 2:39 pm » Post: #20 » Download Post
Hey Maxim, I just had the quote from Wiseco.
I hope that you're sitting down.
Oh I'll keep you in suspense until I can give you the weights tomorrow. I don't want to depress you without a pick me up to go with it.
Thu Jan 04, 2007 6:03 pm » Post: #21 » Download Post
Heres what I posted in another post aaaages go...
All figures are piston complete with rings, wrist pin and circlips
HRC F3 piston : 162g (no it wont fit a stock crank)
MC21/28 piston : 201g
Tyga 300 piston : 227g (yes it will fit your stock crank, no it wont fit your stock bore). Rolling Eyes
maxim
Thu Jan 04, 2007 7:57 pm » Post: #22 » Download Post
Matt@TYGA wrote:Hey Maxim, I just had the quote from Wiseco.
How annoying are you today!!? Wink
If they're lighter than stock I'd pay more than a tenner for them that's for sure...
Cheers Stephen. The 300 piston isn't as heavy as I thought in comparison. Be nice if it was 150g though!
Thu Jan 04, 2007 8:06 pm » Post: #23 » Download Post
Looking back though my emails to and from Matt the pistons in his 300 are 190.4g (I don't know if this is with rings pin and circlip though). I think these were one offs so proddie ones might be a tad heavier. Its still a good saving over the "stock" Tyga pistons though.
Sorry Maxim but you arnt ever going to beat a F3, you might get more hp and more torque but it aint no F3 Wink
maxim
Thu Jan 04, 2007 9:23 pm » Post: #24 » Download Post
Lol Stevie, shout that to me as I come past you on the back wheel shakin my booty at you! Wink
Thu Jan 04, 2007 10:54 pm » Post: #25 » Download Post
Is that in the same dream where you get 78bhp? Wink
Thu Jan 04, 2007 11:06 pm » Post: #26 » Download Post
Hmm... just comparing spec's between the F3 and the TYGA 300, and it's far from cut and dried!
I've uploaded all the images, but I will edit the Posers league table before I publish the URL! Very Happy
I hope to have a minor update done later tonight... who'll be in the lead now though?!
Matt@TYGA
Supporter - Vendor
Supporter - Vendor
Sat Jan 06, 2007 3:19 am » Post: #27 » Download Post
When you compare the F3 and my 300 specs there's advantages for both bikes.
The F3 scores heavily in the crank and piston department. The F3 crank is just so trick compared to the 'stock' indexed and trued crank in the 300. The F3 also gets top marks for the fact that the slugs weigh nothing, so will happily spin to 13k+ all day every day. The bigger Wiseco slugs (check Steve's weights which include rings, clips & pin) obviously have to have a ceiling on them, but are a good improvement over the 'stock' 300 pistons.
The NSR/RS hybrid clutch fitted to my 300 is about half a kilo lighter than the full NSR clutch on the F3, so I'd gain here. There was a fair bit of messing around making new push rods etc, but it's sorted now.
Both run F3 gear boxes so it's a split decision on that one.
Anyway, I think that this 300 mota is about as far as I can be bothered to go for now, apart from optimizing the heads and ignition and fuelling.
The next 300 engine I've got planned is gonna be the next step up, but as soon as I mention it here I know that Steve will forced back into the workshop with Andy hot on his heels brandishing the whip and chair.
Whilst Steve and I were talking b Shocked ll Shocked x over a cup of tea, Steve mentioned that the NF5 crank dropped straight into the MC18 cases. Well, when Steve hopped on the plane back to Blighty I pulled the MC18 & NF5 motors apart and threw the crank at the 18 cases. Unfortunately it didn't drop straight in as the crank wheels are slightly larger in diameter, but bearings etc lined up nicely. Looks like a skim up in the cases is the next plan.
The NF5 crank is now next to the press, and I've got a selection of NSR rods on the bench. You see, the NF5 rods use a 14mm SE pin, but the 300 uses a 15mm pin.
Trouble is that once I've fitted the NSR rods to the RS crank I've then got to make a decision as to build either an NSR300MC18 with RS crank, or an RS300. Either way, they both have huge potential.
The RS300 jumps to the front when you look at the overal spec, and we know it'll go in the NSR chassis, but then it's not an NSR Confused
So what to do?
Wish I didn't have to work for a living Sad
Oh, almost forgot. Andy just sent me my poser points total for the 300. Looks like Mark Brown's factory bike is in real trouble.
Matt@TYGA
Supporter - Vendor
Supporter - Vendor
Sat Jan 06, 2007 9:03 am » Post: #28 » Download Post
As usual, I'm a step behind the rest of the world. NSR-World that is!
Steve just sent me a SMS telling me that I was trying to get a square peg in a round hole....usual story. It should have been the 89 RS crank that drops straight in, not the '92 as I was trying.
He probably told me this back then but I doubt that I was probably too excited to take any notice.
BEEP.....
Another message from Steve.
Matt@TYGA
Supporter - Vendor
Supporter - Vendor
Fri Jan 12, 2007 5:45 am » Post: #29 » Download Post
Glad to see that my bike's back where it belongs on the Poser League Very Happy
Bit of a worry about Steve though not being too far behind Evil or Very Mad
How many points did you give him for that water pump cover Andy?
Hey, don't forget my shirt when you come over, I need a buffer Wink
watfordhorn
1995 Honda NSR250 MC28
Fri Jan 12, 2007 9:20 am » Post: #30 » Download Post
How come I am still bottom (except Andys MC21 which isnt calculated properly either).
My aim for last year was to get off the bottom, now seems that my NSR is destined for the same league position as my poxy football team.....bottom!
Surely with my extra points I have added I can go up a bit, expecially as thats the only reason I splashed out on the new NSR world brake lines. Crying or Very sad
NSR300 Discussion
