mc 18 rk5 end can gaskets
beakergixer750cc
Sun Jan 14, 2007 1:56 am » Post: #1 » Download Post
Question Are they meant to be a sloppy fit? turns out the ones i have in me 16 are same size internal,external diameter and thickness as these ones i have in me rk5 pipes!
Sun Jan 14, 2007 8:34 am » Post: #2 » Download Post
Look in the parts book, it's the same part number for the MC16, MC18r2j and MC18r5k Wink
beakergixer750cc
Sun Jan 14, 2007 8:43 am » Post: #3 » Download Post
yeah i know,sometimes the numbers are wrong Wink
It just seems a bit cheapskatish of Honda to fit a part that clearly doesnt fit properly Confused
Sun Jan 14, 2007 3:18 pm » Post: #4 » Download Post
Yes they are the same gaskets.
When they are new they are quite abit thicker than used one so it doenst need to be any larger out side dia as once the cans are tightened up to the pipe there is a very good seal.
From memory the gasket is about 2mm smaller OD then the can is ID.
beakergixer750cc
Sun Jan 14, 2007 5:13 pm » Post: #5 » Download Post
Yes stephen thats right,only one silencer is not sealing properly and it doesn't matter if i swap gaskets around,why Honda went to the trouble of machining out rk5 silencer 2mm bigger and not making a gasket to suit seems a bit pointless Confused
Is there a gasket sealer you can buy?
Will mc 21 gaskets fit?
Sun Jan 14, 2007 10:27 pm » Post: #6 » Download Post
Why did they put a gasket there at all is the question.
beakergixer750cc
Sun Jan 14, 2007 10:42 pm » Post: #7 » Download Post
I guess any join in the exhaust system has to be air/gas tight,summat to do with pressure waves,and stops black crap spraying out all over the back end of me bike Laughing
Chester362
Mon Jan 15, 2007 6:31 pm » Post: #8 » Download Post
Can`t you just fit two gaskets to the leaky side? Or will it not pull down with two on?
Mon Jan 15, 2007 6:38 pm » Post: #9 » Download Post
Two would be much to thick.
A new gasket should do the trick as when they are new they are close to 2mm too big and take quite abit to compress, this gives a really good seal. Once they have been removed once though they will almost always leak.
beakergixer750cc
Mon Jan 15, 2007 10:30 pm » Post: #10 » Download Post
will mc 21 items fit?
