That'll be an HRC transmission with optional gears going in the Racer then - not bad for a tad under £50! I wouldn't sell it for less than 5 times that!! _________________ Andy.
We were going to fit the ram air box to the racer yesterday but decided untill its full F3 we will stick with the standard F3 air box. _________________ If I have to take the carbs off once more...
So wheres the HRC gearbox angle grinder Would'nt it fit in the picture
_________________ Harley Davidson is the worlds most efficient way to turn petrol into noise without the harmful side effect of horsepower.
Seeing as you were going on about weight saving so much Stephen, I'm surprised to see you're still using the original seat foam which has got to be made of dark matter incased in lead it's so heavy! _________________ NSR300R - Why did i ever have a 250...
