Hey guys, last nite i was riding along and everythin was fine, then suddenly my tacho and temp gauge just stopped working. There are no lights and the needle is not moving, so i assume that this is just a power problem. However I have just bought the bike and am not sure where to start looking. Any help would be appreciated. Thanks!!
Well it's unlikely to be the temp sender and ignition unit both failing at once.
It's also unlikely to be the earth since they use the bike common earth, and the whole thing would have died if that failed.
However, I suspect the positive (power) to the instruments is from the same source, so I'd start by checking the fuses. If they're all fine, then check the plugs to the instruments are fully home - and check the pins are clean and not coroded. _________________ MC21SP Plaything
got it fixed thanks for your help tho! It was just the plug at the back of the instruments, i thought it would be something like that i just hadnt had time to look at it yet. Its an MC21 by the way!
Good news. Glad it was a free fix! _________________ MC21SP Plaything
