Buy a set of 21 carbs and you can have one, and a spare carb to do nothing with, unless you go the trouble to make up a shaft and pulley and...and ...and...
And machine up the right size carb spacer, and throttle end stop, and a cable for throttle and oil pump and then start thinkning about air box/filter choke and and and... _________________ Farting is funny
