mc28 mods, few questions plz
rodney007
Fri Feb 09, 2007 12:44 pm » Post: #1 » Download Post
ok, few questions please ,(nsr noob)
can i modify the stock airbox in any way with stock carbs etc, to see a increase in power without jetting>?,
and does cleaning out chambers that have done 22k increase exhuast flow for a small power increase or power restore?
any help appreciated,,,
Matt@TYGA
Supporter - Vendor
Supporter - Vendor
Mon Feb 12, 2007 2:23 am » Post: #2 » Download Post
Only if the engine is running rich to start with, will you see an increase in power on stock jetting with an airbox modified for more air flow.
If the chambers are clogged up then yes, you will see an increase in power when you clean them up.
My advice though, which will be echoed by everyone, is that if you're after more power then you MUST sort the carburation out at every stage of modification, or you're asking for a seized motor and a big rebuild bill.
rodney007
Tue Feb 13, 2007 9:18 am » Post: #3 » Download Post
ok thanks for your help mate..
