castrol a747
paul
castrol a747
Tue Feb 13, 2007 7:07 am » Post: #1 » Download Post
my dealer tells me they stoped making a747 about 4 years ago, and that castrol r30 is the replacement, now I thought that was a 4 stroke oil
so can i put r30 in my rs125?
PhiLLaY
Tue Feb 13, 2007 7:39 am » Post: #2 » Download Post
I thought R30 was discontinued. Castrol a747 is still avaliable AFAIK
Stock and really slow MC28SE Repsol Rep... =(
rc46
Tue Feb 13, 2007 8:33 am » Post: #3 » Download Post
We can still get A747 here, its a bit hard to come by but 3 shops do it, best bet is get onto
http://www.castrol.com/castrol/multipleproductsection.do?categoryId=8290031&contentId=6007501
New zeland Right?, youll see A747 and R30 so they still do it, youll just need to browse around and find out which shop is closest to you!!!
Matt@TYGA
Supporter - Vendor
Supporter - Vendor
Tue Feb 13, 2007 1:27 pm » Post: #4 » Download Post
Don't get confused with R30 being the same as A747. They're different, and their applications are different.
R30 is a castor oil, and is pretty good at everything. We used in transmissions on NSR250 and RS125/250 as it's lubricity is excellent, but it's a tad thick and gooey. Not to be used in wet clutch applications though as it'll slip like a...errr...slippery thing!
As a two stroke oil, R30 also has it's uses. It mixes with alcohol without breaking down so that's one useful thing to note. It also retains a very high film strength at high rpm, which is a necessity for small capacity/high revving strokers such as fixed gear go-karts.
In lower revving engines (~14,000rpm) it's not so good. It smokes and can gum up the rings, foul plugs etc. You also need a lot of it in the premix. 15~20:1 mixes are not unusual and this can affect throttle response.
R30 doesn't like to mix with other oils, which is ok if you're only ever gonna use R30, but don't think that you can change brands/types without completely draining and flushing.
A747 is a castor based two stroke racing oil. It's application is for racing two strokes. simple as that.
The usual mix is 30:1, but we've used very lean ratios in experiments with Castrol with no real bad affects other than a temperature rise (and associated power loss).
A747 also has the magic of replacing the octane of the fuel that it displaces (allegedly), so if you have a 100 octane fuel and add A747 at 3% (or whatever) you won't get a drop in octane. R30 doesn't do this. The octane level will drop.
A747 is for premix only. It will not flow through an injector so don't go this route.
A747 was developed for leaded fuel, and although I've used it without issue in uleaded a new generation of A747 is available now (XR77), specially blended for ULG.
It's not a good choice for the road, unless you ride like a nutter at all times, as it'll smoke and foul plugs at low rpm. It's a race oil, so works within it's design window, which is high rpm, high pressure, high temperature environments.
Oh, there's one thing that both oils do have in common, other than the castor base, and that's the smell. It's delicious!
You can actually buy little 50cc packs of R30 here in the bike shops to throw in the fuel tank just for the smell. It's great!
nsr.wayne
Tue Feb 13, 2007 6:23 pm » Post: #5 » Download Post
I used Castrol R30 in my stock TZR 125 with no problems .It did gum the rings up but I did about 5000 miles using it before this happened,I only used it coz of the smell Very Happy .
As well as Castrol TTS they make R2 which can be premixed or used through the oil pump. I use it but only coz of the smell as it close to the smell of R30/40 but it aint cheap.
Harley Davidson is the worlds most efficient way to turn petrol into noise without the harmful side effect of horsepower.
pbekkerh
Tue Feb 13, 2007 9:48 pm » Post: #6 » Download Post
Very Happy Very Happy Very Happy Very Happy
Poul
MC21SE, KISS box
MC21SP, HRC box, racing loom
paul
Thu Feb 15, 2007 6:05 am » Post: #7 » Download Post
so can I run r30 in my rs125? a747 was the hrc recomendation which is why I wanted that first
Matt@TYGA
Supporter - Vendor
Supporter - Vendor
Thu Feb 15, 2007 10:36 am » Post: #8 » Download Post
If HRC recommend it, then use it.
