One NSR Cylinder not firing then the ohter........??????
nickvr
Sat Mar 03, 2007 7:56 pm » Post: #1 » Download Post
Hi. I have a NSR250 MC18. Sothing very weird started a few weeks ago. It was obvious the right side pipe had no fire and the power was non-existend. Took it to workshop, they replaced sparkplugs and cleaned the fuel line. Afterwards is was fine for a few days. Now the left side is dead / no firing.... I've check the plugs are there are spark. Can this again be insufficient fuel to the other side? Any ideas will be appreciated.
Many thanks
fenton
1990 Honda NSR250 MC21
Sat Mar 03, 2007 8:44 pm » Post: #2 » Download Post
try going round the wiring loom and cleaning all the pins to and from the ignition system as it sound like they mite be blackened or corroded then put a small amount af vaseline on the pins
fenton
Sat Mar 03, 2007 8:48 pm » Post: #3 » Download Post
also check that the carbs are clean nothing is blocked
nickvr
Sun Mar 04, 2007 5:22 am » Post: #4 » Download Post
Definitively not spark related! I'll check the tank breathing. The one side in completely dead. I'll check the fuel pipes to the carb. Thanks for advise thus far, much appreciated.
fenton
Sun Mar 04, 2007 11:31 am » Post: #5 » Download Post
it there compression in the bad side ?
nickvr
Sun Mar 04, 2007 12:55 pm » Post: #6 » Download Post
Yes. Compression is good!
fenton
Sun Mar 04, 2007 1:28 pm » Post: #7 » Download Post
were are you in the world ? because ive read that there has been some dirty fuel going about
nickvr
Sun Mar 04, 2007 2:03 pm » Post: #8 » Download Post
I'm following up on a tip that the spark plug (BR9ECM) may cause problem even if it seems like firing (outside the head). Maybe its just Murphy this time around
fenton
Sun Mar 04, 2007 2:06 pm » Post: #9 » Download Post
i have had plugs go bad but sounds like fuel to me mate is the plug wet ?
nickvr
Mon Mar 05, 2007 7:55 pm » Post: #10 » Download Post
Hi. Long shot but I think I may be onto something. Opened and cleaned the carbs again, changed plugs and generally cleaned stuff. Got everything together earlier and guess what, the left side is dead (the right side was dead).... Again I checked plugs and fire, all fine. I then got a brainwave and opened the bottom drain bolt, and only a few drops of fuel came out!!! Both carbs were almost completely dry. I tried blowing air into the intake and couldn't. I realized it could only be the floats. Removed the carb, opened the bottom and saw that the float valve was stucked. Removing it, I can clearly see some dents and scratches (here and there rough edges). The other side more or less looks the same. I'm pretty sure that this may cause this one side then the other side "dead" story, sticky float valves. Do you think a would still be able to get spares e.g. float valves and seats? Lastly, do you adjust the float levels?
Tue Mar 06, 2007 1:55 am » Post: #11 » Download Post
Probably don't need new parts, just a good clean. Float heights are important and I think Andy has something on this in his techy section.
nickvr
Tue Mar 06, 2007 4:54 am » Post: #12 » Download Post
Hi. Where can I find that section from Andy?
fenton
Tue Mar 06, 2007 12:35 pm » Post: #13 » Download Post
HERE OR HERE
nickvr
Tue Mar 06, 2007 3:03 pm » Post: #14 » Download Post
Hi. Nope, nothing there about float settings...
Tue Mar 06, 2007 3:37 pm » Post: #15 » Download Post
Yes there is...
