I cant believe it,bloody things playing up again
switch bike on,servo working blip throttle a few times valves open and shut ok then it goes to the closed position and stays there until i switch ignition off then on seems to work ok as above and then stops again:x
servo unplugged,valves fully open,slip clutch a little to get going,and she goes very well indeed,its just annoying because servo works at first then stops i'm thinking rc control unit as my spare servos act the same!
It could simple be a duff servo controller. The controller on the MC16 is a seperate box, and you should be able to pick one up cheap somewhere. _________________ Andy.
There was an MC16 RC valve controler on ebay last week going for £10 I think. Might still be there. _________________ If I have to take the carbs off once more...
