I believe its a 900rr with airtech 'NSR' bodywork and vfr swinger. Collest thing are those Keihin FCR carbs tho! _________________ MC21 300R w/SE bits, Rossi 2001
MC28SE Silhouette Repsol
Yes, the FCR39s are very cool, but I don't believe that they are the magnesium ones. Those are very rare and worth about $20k by themselves. They were made for the V4 NSR500 race bikes and a friend of mine has a set on his RC30.
Joel _________________ 1994 MC28 Rothman
TSR250 AC28M
Would it be possible to use them on a 2t? Please forgive my ignorance, but is there a difference between 4t and 2t carbs? Other than jetting.
Hrmmmmm FCRs on a NSR?l _________________ MC21 300R w/SE bits, Rossi 2001
Infact most RC30's used 4 x 35mm CV carb(even the HRC kit ones) The FCR wasn't really used untill the short port NLOB engine came out and then later on the used with the TPS ign system on the pre 1993 RVF racer. _________________ If I have to take the carbs off once more...
Yes, all RC30s came stock with CVs. I still have a set around as I put the FCRs on it and it was then badass. Putting FCRs on the RC30 is useless unless you have a modded motor. Mine was worked very nicely by Dan Kyle and put 123hp at the rear wheel by the time Jim Granger and I were done with it. Not bad for a street going version. I also had period Ohlins forks and shock. Too much for the street imho.
TSR250 AC28M
Personally, with the $30,000 that was "invested in this bike", I would have bought a Repsol Fireblade and kept £5000 to buy & mod another NSR 250 _________________ Warning:
This post may contain traces of peanut!
