Clutch problems
nsr Moggy
Clutch problems
Tue Apr 10, 2007 5:45 pm » Post: #1 » Download Post
Help the clutch push rod on my MC21 Dry clutch has got jammed further back than it should be and the clutch arm underneath the engine will not turn how can I free this?
thanks in advance Moggy
MC21 SP
Tue Apr 10, 2007 7:01 pm » Post: #2 » Download Post
Do you know how it got jammed so far back? Are you sure its not just the oil seal stopping you from removing the push rod?
nsr Moggy
Wed Apr 11, 2007 7:29 am » Post: #3 » Download Post
It got that far back through my stupidity was putting new plates in and put the wrong fibre plate in first so the push rod pin was not meeting the pressure plate so I decided to put an extra ball bearing in the push rod pin
Doh
MC21 SP
nsr Moggy
Fri Apr 13, 2007 11:13 am » Post: #4 » Download Post
Just incase anyone is interested or stupid enough to do this again it was pretty simple to sort out take the side casing off the bike then take out the 6 bolts or so holding the gearbox in give a gentle tap with a hammer on the front sprocket carrier the pressure was then released off the bar . then put bike back together again
MC21 SP
