'21 electrical demon?
horde
Fri Apr 13, 2007 7:14 am » Post: #1 » Download Post
hey gents, another day in nsr paradise ended with a ring-a-din-ding-pffffft Evil or Very Mad
Was out riding, everything running beautiful, when I noticed a battery smell, I was approx. 40 km's from home, so I decided to turn around home to check it out.
Got 3/4 of the way home, and every time I pulled up at lights, could smell battery. Next, the indicators started acting erradically, and the lighing on the guage cluster was pulsating/flashing.
Very close to home and now I've noticed the seat is quite hot Shocked (tyga tail, wiring is under seat), and the bike is starting to rev a little erradically. Got the bike home and it literraly stopped in the driveway.
Now, after letting it sit for a week, I've thrown the key in it, but the guage cluster does not illuminate, nor does the powervalve make its motor noise. Checked the battery, reading 12V, battery is 2 years old. checked battery connections and fuses, O.K.
Any idea whats cooked or whats the problem?
Any help would be hella appreciated, as the Melbourne winter is yielding sunny 26 degree C days in two week succesions, need a ride! Laughing
........."I love the smell of 2-stoke in the morning.......Smells like victory"............
MC21 Pentax SP...... TYGA'D
maxim
Fri Apr 13, 2007 7:52 am » Post: #2 » Download Post
Check your rectifier. If you haven't mounted it correctly you could be getting those probs...
nsr250racer
Fri Apr 13, 2007 6:42 pm » Post: #3 » Download Post
Maxim, with the TYGA Subframe, what would be the correct way to mount the Reg/Rect ?
FILOLI - Fight, Love, Live
maxim
Sat Apr 14, 2007 12:20 am » Post: #4 » Download Post
Erm, best I leave that for Matt or Paul to answer so as not to mis-inform you... Confused
horde
Sat Apr 14, 2007 9:56 am » Post: #5 » Download Post
yeah might have to try that, i've got it mounted by one bolt to the subframe, however I did make a large thick alloy plate for it to sit on to soak up the heat, but in hindsight, I didnt put any electrical paste between the two.
As I remember the battery was VERY hot......
matt, paul, andy, any works of wisdom? Confused
Cheers gents
horde
Tue Apr 17, 2007 2:05 am » Post: #6 » Download Post
bump.....
how do I check the reg/rect ?
thanks
Tue Apr 17, 2007 6:06 am » Post: #7 » Download Post
This search took 10 seconds!
http://nsr250.net/forums/viewtopic.php?t=4404&highlight=reg+rec
Covers checking, voltage, and mounting, all in one topic.
There are plenty more topics too, but if you can't be bothered to look it up, then neither can I.
