I need to convert my NSR to GP shift o match my other bikes, I was looking at it and it doesn't look so easy. Does anybody know what is involved or if its even practicle? _________________ james
MC21 Rothmans
RS250
RC31
CRF250X
748R
Porsche (many)
Yes reverse shift. Many uin hte US call it GP shift. I wanted to use the stock rear sets to retain the stock appearance. _________________ james
MC21 Rothmans
RS250
RC31
CRF250X
748R
Porsche (many)
If I wanted to do that with the stock rearsets, I would hack the pushrod in half, and make a pivot point off the front lower mounting. I reckon that would work OK.
I'll rough up a diagram, as it's easier to illustrate than describe... being as I'm no teacher!!
Does that make sense?
Of course the geometry will need a little bit of fiddling with, but I'm sure you can get the idea. This will allow the actuator arm on the selector shaft to stay roughly in the standard orientation. _________________ Andy.
Some like street shift and somne like race shift (reverse, GP etc). I like street shift on a street bike, race shift on road racers and street again on MX and Supermoto.
Andy's diagram would work, and you could fiddle around with the ratios for a soft comfortable shift that diddn't destroy your boots and toes, or a harder, more positive shift.
I've never run an NSR more than about 2 minutes with stock steps, so I've no idea why you can't run race shift. Why is it?
Race shift allows you to just stamp on the lever to change up the cogs, which can be handy if you're at full volume through a fast left hander, well banked over and you can't get your foot under the lever to shift up.
It can also be a little more tidy hammering down the chute and just sort of resting your foot on the lever to switch cogs.
Check out Max Biaggi when he's down the straight. He uses normal street shift and everytime he hooks a gear his knee comes out a couple of inches. Any 125cc GP team boss would complain bitterly about that as you'd lose 1mph atthe end of the road.
He is 'reasonably' quick though Matt so I'm sure they'd grant him a little artistic license... _________________ NSR300R - Why did i ever have a 250...
You can switch it with the stock rear sets. I've done it with no issues in the past. You may need to do a little cutting/grinding if your going to keep the side stand, but it's doable. _________________ Charles Gallant
Thanks for everyboy's comments. I guess I was right, this wont be easy.
Andy: I couldn''t quite follow yoour description. Are you saying to use some kind of remote servo? _________________ james
MC21 Rothmans
RS250
RC31
CRF250X
748R
Porsche (many)
