I need to replace the stock right hand clip on that was bunged up years ago. Is there a aftermarket replacement that will work with all of the stockcontrols that is lighter maybe alloy? Or is simply replacing with stock the way to go? Thanks in advance. _________________ '93 MC21 250sp Repsol "Doohan"
What is the diameter of the fork? I use Gilles GP Light. The bar is removeable from the clamp but non adjustable set at 6 degrees I think. RRP is around £99 depending which model will fit. _________________ http://www.rgv250.co.uk http://www.thetuningworks.com
