I Just installed an HRC wiring harness on my 92 MC21 and noticed that there is no wire/plug running to the oil pump solenoid. With this harness do i need to run premix? If so, what ratio would you suggest i run?
I will be running the bike occasionally on the track but still have all my lights wired up for the street. Here in the states I cannot find Castrol A747 or Elf HTX 975, 976, or 909 premix oils. Can you give me an alternative oil for street use?
