Spare MC18 2J/4J in London for testing
Thu May 31, 2007 4:43 pm » Post: #1 » Download Post
I've still got a low rev misfire on the front cylinder and wonder if it's a PGM problem
The top end has been recently completed and have about 70 miles running in so far.
New parts fitted;
air filter element
coils
front plug cap
Gibsons have had it on their dyno and say it runs ok through the rest of the range after cleaning out the pilot jets.
Does any one know if a Honda dealer would have test equipment or does anyone have a spare I could try out?
Chester362
Thu May 31, 2007 5:37 pm » Post: #2 » Download Post
A few people on here, (myself now included!), have had problems with the flywheel ignition pick ups. They`re the two units outside of the flywheel rotor. The wiring to them can get damaged as it enters the plastic case of each unit.
They`re easy enough to check, have to take the lower fairing & genny side cover off. 4mm Allen key to remove the mounting bolts for the pick ups.
