mc 21 250r clutch problem
warbird110
Tue Jul 03, 2007 2:48 am » Post: #1 » Download Post
hi i need help just got nsr 250 r mc 21 wet clutch just got bike started changed all fluids go to pull in clutch feels good but dosent work pops in gear when i shift but pull in clutch no help dosent disenguage the gear is there anything i can check before tearing into engine please help its killing me i want to ride so badddddd lol thanks for any help brent
j911brick
Tue Jul 03, 2007 5:10 am » Post: #2 » Download Post
Is the cable still attached? Are you getting any resistance?
james
MC21 Rothmans
RS250
RC31
CRF250X
748R
Porsche (many)
warbird110
Tue Jul 03, 2007 5:11 am » Post: #3 » Download Post
yes cable feels good
j911brick
Tue Jul 03, 2007 5:14 am » Post: #4 » Download Post
Are you sure you didn't loose the bearing in the shaft?
james
MC21 Rothmans
RS250
RC31
CRF250X
748R
Porsche (many)
warbird110
clutch
Tue Jul 03, 2007 5:15 am » Post: #5 » Download Post
never opened how do i check it
j911brick
Tue Jul 03, 2007 5:18 am » Post: #6 » Download Post
Your going to have to take it apart. Something isn't right.
james
MC21 Rothmans
RS250
RC31
CRF250X
748R
Porsche (many)
warbird110
clutch
Tue Jul 03, 2007 5:20 am » Post: #7 » Download Post
do you mean pull the side case to see clutch is the bearing under there or how do i check to see if the bearing is there thanks brent
j911brick
Tue Jul 03, 2007 5:36 am » Post: #8 » Download Post
You hve to pull the ide cover off. There is a shaft that goes though the center of the hub and that i what puhe the preure plate out. The shaft is actually in two pieces and a single ball bearing between them. Check the parts diagram on this web site.
james
MC21 Rothmans
RS250
RC31
CRF250X
748R
Porsche (many)
warbird110
clutch
Tue Jul 03, 2007 5:39 am » Post: #9 » Download Post
thank you i will try tomorrow anything else i should look for while im in there
j911brick
Tue Jul 03, 2007 5:45 am » Post: #10 » Download Post
Make sure the pressure plate is on correctly. Check the plate stack for the proper order and measure the thickness of the stack.
james
MC21 Rothmans
RS250
RC31
CRF250X
748R
Porsche (many)
warbird110
clutch
Tue Jul 03, 2007 5:49 am » Post: #11 » Download Post
what about the part that the clutch cable moves could it be broken inside im talking about the spring loaded part that goes into the case that is at bottom of case thanks if so is there away just to check that
j911brick
Tue Jul 03, 2007 5:58 am » Post: #12 » Download Post
Anything is possible, but I doubt it. That spring really doesn't do much.
james
MC21 Rothmans
RS250
RC31
CRF250X
748R
Porsche (many)
warbird110
clutch
Tue Jul 03, 2007 6:11 am » Post: #13 » Download Post
what is attached to the spring going inside the case is it a shaft or gear thanks brent
Jeff SZ
Thu Jul 05, 2007 1:12 am » Post: #14 » Download Post
How did you make out ?
I had a similar problem and it was just the steel plates were stuck to the frictions from minor surface rust, bike sat a while before I got it. Took everything out and brillo cleaned the steel and worked fine.
If you need clutch parts I have a hub and basket brand new.
warbird110
clutch
Fri Jul 06, 2007 3:08 am » Post: #15 » Download Post
no but thanks for the info and parts thanks very much i havent had time to do it yet but i will post when i get into it and figure out thanks again
brent
