pulse generator
thaiwade
pulse generator
Fri Jul 06, 2007 2:13 am » Post: #1 » Download Post
Anyone know the best way to test the pulse generator/ignition pickup?
1990 MC21
Bodoe
Fri Jul 06, 2007 7:17 am » Post: #2 » Download Post
If you have access to digital multimeter (or ohmmeter) you can probably set it to measure resistance with the function that a sound is made when there is no resistance.
Then measure over the pickup and earth. Turn the flywheel so that the pegs on the flywheel passes by the pickups and you should hear a beep from the meter (or se that the resistance is zero).
Please revise wiring diagram on in the workshop if you are unsure where to measure.
MC21, GP-Replica (Daijiro Kato, Telefonica Movistar Team 2001)
jeff350lc
Fri Jul 06, 2007 9:16 am » Post: #3 » Download Post
Like the man said, but never ever use the bleep test. You could have every strand of wire broken apart from one, and it would still bleep. Check the resistance reading.
