From the scematic there are only two connections to the valve motor, so is it +-12v or something in between, or are they analogue signals with variable voltage/speed ?
Can't do it myself, one pgm is busted the other machine needs cylinders and I'm at work.
What is the current draw of the valve solenoid under normal conditions ? _________________ Poul
MC21SE, KISS box
MC21SP, HRC box, racing loom
Chances are that if Honda felt so inclined they would use a stepper motor in the RC valve servo now. It would be extremely accurate and very fast. probably cost more though.
