hi, are the crankcases interchangeable between the different models ? am rebuilding an mc21 motor but need new cases, would 16,18 or 28 cases do the job ? are there any advantages using different cases ?
If you want to use the '21 crank then you will need either '21 or '28 cases as the crank wont fit in the others. _________________ If I have to take the carbs off once more...
