will a bridgestone BT96 front, 110/70 17 work ok with a bridgestone BT090 rear 150/60 18 on my MC18 r5k ? or should i just stick with a pair of BT090's ? it will be road use only, i have the chance of a new BT96 front very cheap, as they are no longer made no rear BT96 is available.
Ring up Bridgestone and ask. They're usually quite helpful and won't recommend you use the front, but may suggest that it shouldn't be a problem... _________________ NSR300R - Why did i ever have a 250...
