mc 21servo/ power valves
erk4shooter
Sat Aug 25, 2007 1:04 am » Post: #1 » Download Post
Just got a mc21 not running and was wondering if when you turn the ignition on you should hear the valves/ servos doing self test etc?
Eric
j911brick
Sat Aug 25, 2007 3:30 am » Post: #2 » Download Post
No. They should only move if they didn't "park" in the right spot. At least mine work like that on 2 different PGMs.
james
MC21 Rothmans
RS250
RC31
CRF250X
748R
Porsche (many)
Sat Aug 25, 2007 11:51 am » Post: #3 » Download Post
You're thinking of the RD350 aren't you? Wink
The NSR doesn't do that, though as said above, it will drive them to the start position if they weren't there at shut down. Manually rotate them with the ignition off, and then switch on to see if they move.
erk4shooter
Sat Aug 25, 2007 10:17 pm » Post: #4 » Download Post
Very Happy not an rd i used to have a rz500. should the valves move freely? i can't move these at all manually, maybe a seizure?
Eric
j911brick
Sun Aug 26, 2007 1:15 am » Post: #5 » Download Post
With the ignition off and a slight effort you should be able to move the servo. If not, take the cables off and make sure the PVs are not frozen. If the servo does not work you may have damaged the PGM.
james
MC21 Rothmans
RS250
RC31
CRF250X
748R
Porsche (many)
erk4shooter
Sun Aug 26, 2007 3:24 am » Post: #6 » Download Post
Very Happy Thanks for the advice guys. I got the tank off and played with the servo everything seems to be working ok. till next tme, thanks
Eric
