question about 300 kit...... again
sandkingeleven
Wed Sep 12, 2007 11:27 pm » Post: #1 » Download Post
im going to buy a tyga 300 kit but ive a few questions about it which dont seem to be covered.
what state of tune does the kit come with ?(does it have much potential for more power)
matt had said there a lightweight piston comming out but i cant find it on the website, is it available yet?
will normal race pipes work well with a tuned 300 as they've been designed to work with the 250 not the 300?. maybe get custom pipes made?
i just want to make sure its gonna be worth the effort as ive already got a pretty strong motor. if so theres gonna be some tunned barrels with single ring pistons up for sale!
any help would be much appreciated
wadda ya mean its too fast!
Thu Sep 13, 2007 12:29 am » Post: #2 » Download Post
You need to look a little harder, try here.
sandkingeleven
Thu Sep 13, 2007 1:53 pm » Post: #3 » Download Post
thanks.
mhunter1175
Sat Sep 15, 2007 7:50 pm » Post: #4 » Download Post
Let me know if you decide to do it I am very interested in your take off parts if they are in good shape!
Mike
Sat Sep 15, 2007 9:09 pm » Post: #5 » Download Post
A lot of people here like the 250's cause they are 250's, only Steve and Matt (I think) have ridden any modded 300 (and he's got the F3 to compare it with). A well sorted std 300 is quicker than almost 250 but doen't have the top end whiz.
Maxim has a modded 300 on the way and a proposed showdown with Steve's F3.
Sat Sep 15, 2007 11:17 pm » Post: #6 » Download Post
I've ridden Matt's a couple of times, but not in it's latest guise... the ride was on last time I was in Thailand, but I'm afraid the previous two rides has left me uninspired.
The bike itself is magnificent -- trick parts, and very well built, but I am convinced now that no 300 will ever float my boat.
Sorry Matt! Confused
sandkingeleven
Sun Sep 16, 2007 1:24 am » Post: #7 » Download Post
ok so a if a 300 is properly tuned, light piston fitted ( so its the same weight as a standard piston ) shouldnt it have the same revability as the 250?
next question, which tuner for a nice stage 3 tune
Sun Sep 16, 2007 1:30 am » Post: #8 » Download Post
Er, Matt @ TYGA?! Confused
Who else is more qualified to modify a 300 than the guy who designed it?
sandkingeleven
Sun Sep 16, 2007 1:41 am » Post: #9 » Download Post
i didnt know he'd tune it too to whatever specs i wanted. think im gonna have to have a chat with tyga.
been offerd some old rs250 pipes cheap, will they work well on the nsr?
Blimey this is long....must have too much time on my hands!
Sun Sep 16, 2007 7:54 am » Post: #10 » Download Post
I think that this may be a good time to jump in.
The 300 in it's 'normal' state is not for all, as it loses that 250 kick in the pants when it comes on the pipes. It's not that it makes less power, just that the transition from mid to high is not violent like a sorted 250. The rev ceiling is also kept lower due to the heavier pistons/ design etc.
However....
Tuning is of course possible. Andy rode my bike in both it's sort of normal, and stage one guises. Everything worked, but Andy is very hard to please as far as strokers are concerned and the 300 just has big wads of mid range that will stay pretty much where it is unless I make some new pipes.
My latest spec (stage III 1/2) is using a stock (trued) crank, but just about everything else is non-normal. In the top we've got Wiseco slugs in radically altered cylinders with VHM heads running avgas. Still using the normal TYGA pipes, which work great and allow revs up to 13,000rpm, but still give that juicy mid range for the lazy among us.
From the crank back we've got RS250 NF5 straight cut primaries with NF5 clutch and NF5 transmission. Countershaft is NSR so that I can run NSR sprockets, but NF5 could be fitted if necessary. Clutch case cover is NF5 with a plate fitted to fill in the kick-starter bit. Have to push start this puppy.
The water pump is removed and a Bosch electric pump control the flow.
Ignition is taken car of by an NF5 system that uses a NF5/Dash 125 hybrid flywheel. This can obviously be advanced and retarded in the same was as the NF or F3 ignitions.
Carbs are 38mm HRC jobbies, with '92 NF5 big reed valves. Needed a day of chopping the cases to fit these bad boys!
The brain is F3 PGMII with changeable ignition map chip.
Does it work?..........Oh yeah
Was at Bira Circuit this morning cutting a few laps for fun. Came up behind an '03 GSXR750 down the chute and blinking flip I had to pull out the slip stream and pass the big fat fourstroking lump. Yep, I was pretty chuffed with that. Carbs were a jet size rich, but I wasn't gonna mess with that. Could've also done with filing half a tooth off the rear sprocket, but this is a street bike so I couldn't be bothered.
Could be faster of course, if I knocked up some specific pipes for the tune.
Probably '91 RS250 NF5 pipes would be a reasonable choice. I used these as a base for some pipes we made for tuned NSR a couple of years ago and they worked really well, but in true RS fashion it was the mid range that jumped ship and ran to hide up in the 12k band
Basically, the TYGA NSR pipes are designed for peak around the 11500 mark, with good mid range and good over rev, but my 300 cylinders are cut to work in the 12k+ arena, so I've a good mind to shorten the pipes a tad to shift the tuned length up the scale to match the cylinders closely. Mid will suffer but I don't think that will matter too much. This motor was pulling clean as a whistle from 4k up to gear change at 12,500.
So can it go further?
I think it's possible.
The first issue is of course the pipes for a modified cylinder, but this also rings true too for a modified NSR250 cylinder. One other 'problem' is the stock NSR crank. It's ok, but it ain't an NF/F3 crank by a long shot. The problem with those (NF) cranks is the rods, or more specifically the small end size, but there are no rules, so it's possible to fit the NSR rods onto the F3 crank and go from there. Another good point here is that I've just found a bloke forging rods. His samples looked pretty good, so I'll give him an NSR rod and see what he can do.
Ignition is quite a simple task of throwing away the stock electrics and fitting a fully adjustable unit. However, getting one to work with the stock harness as a plug 'n' play is proving a bit of a pain.
What else can we do? FI? HRC tried and abandoned it. Fast but fiddly. Bimota got it all at 6's and 7's. Megasquirt claim that their system can be set up perfectly with patience and experience, but I doubt it's ever gonna be that much better than a well set up carb. TPS etc mapping would be handy though.
Oh well, I guess I'll have to think up something else to please Andy.
Got my eye on a 50cc two stroke mini Motard. I reckon with a bit of whizzing that could be making some serious power up around the 14,000rpm mark. Oh what fun that would be Laughing
sandkingeleven
Mon Sep 17, 2007 3:12 pm » Post: #11 » Download Post
matt that sounds awesome, all the whack at the top and still half decent midrange.
so thats decided then, 300 kit here we come!
i even started looking into the rd350 route which cub cylinders to big bore it but itd be nice to keep some of the original nsr Laughing
just out of interest did you get it on the dyno?
