Stubborn cylinder head
Flyboy
Mon Sep 24, 2007 6:21 pm » Post: #1 » Download Post
Any suggestions on how to get this cylinder head off my MC16?
Got a top end rebuild kit from Tyga and so far haven't had any luck. Been using a rubber hammer as well as giving her a good pull. Have a set of brass punches but wanted to ask before using them as I don't want to damage the head as I plan on re-using it. Any Suggs?!
Confused Ken
"Save a Tree, Eat a Beaver!"
http://www.bikepics.com/members/canflyboy/
cgallant
2001 Honda RS250
Mon Sep 24, 2007 6:34 pm » Post: #2 » Download Post
take the entire cylinder off with the head still stuck on the cylinder. This way you can get at it from behind the cylinder head.
use the old cylinder (padded a little) and a rubber mallet to help it out. also, soaking it with WD40, or something penetrating to help it out may be an option.
Charles Gallant
Flyboy
Mon Sep 24, 2007 6:38 pm » Post: #3 » Download Post
Thanks for the quick reply cgallant, Appreciate it, I guess I should clarify Very Happy al lil more though. What I meant by the cylinder head was the cylinder itself, sorry bout that. I'm having trouble getting the forward cylinder off, any suggs? Confused
Ken
sandkingeleven
Mon Sep 24, 2007 7:15 pm » Post: #4 » Download Post
has it seized?
wadda ya mean its too fast!
Flyboy
Mon Sep 24, 2007 9:08 pm » Post: #5 » Download Post
NOpe, hasn't seized, just due
for an overhaul. Any suggs aside from what should've worked? (beating it with a rubber hammer)
sandkingeleven
Mon Sep 24, 2007 10:16 pm » Post: #6 » Download Post
well i would have suggested a rubber hammer but youve already tried it! if it still doesnt come off with some perserverence try putting the cylinder head back on and turn the bike over. the compression might shift it.
few years back id seized my yz250 absolutely solid and had the same problem. i ended up putting a strop round the head and attatching some chainblocks Laughing
hope you dont have to go to that extent
cgallant
2001 Honda RS250
Mon Sep 24, 2007 11:12 pm » Post: #7 » Download Post
what you could do then is to use the cylinder head studs to "pull" the cyinder off the cases. Basically build a plate that has holes that the cylinder head studs can slide into. Attacht that plate to legs that reach down around the cylinder and meet on the case. Use the head nuts to "slowly" lift the cylinder off by tightning the bolts down a turn at a time for each nut.
So basically think of a bearing puller but for the cylinder.
Charles Gallant
cgallant
2001 Honda RS250
Mon Sep 24, 2007 11:13 pm » Post: #8 » Download Post
o, but make sure your piston isn't stuck, as forcing the cylinder off could damage the connecting rod.
Charles Gallant
Flyboy
Tue Sep 25, 2007 2:36 am » Post: #9 » Download Post
Worked like a charm! I used an old piece of steel and bent it in my vise, drilled a few holes like suggested and after a few extra cranks pulled the head right off the case. Then I jiggled it off.
Checked the crank thrust clearance once I got the piston off and its .59mm, so I'm very happy there's lots of life left in this little rocket.
Thanks again,
Ken Very Happy
Tue Sep 25, 2007 12:48 pm » Post: #10 » Download Post
I had a similar problem getting the top cylinder of my '28, I used an old hammer handle (just a bit of wood really I guess) and hit that with the mallet rather than try to hit the pot in situ.
cgallant
2001 Honda RS250
Tue Sep 25, 2007 1:05 pm » Post: #11 » Download Post
fontyyy wrote:... try to hit the pot in situ.
When did England start teaching something other then English in schools? Razz
Charles Gallant
Tue Sep 25, 2007 2:28 pm » Post: #12 » Download Post
Sounds more like an American bastardisation! Oops, I mean Americanism!! ROTFLMAO
Should read en situ
Oh, and message to Ken... Hit it harder! Very Happy But whatever you do, DON'T try lever it off. (Probably obvious, but you never know!)
It'll only be the gasket holding it all together, and possibly (but highly unlikely) some corrosion between the cylinder locating dowels and the studs. I will put my customary 50p on there being 1/2 the gasket left on the cylinder and 1/2 left on the crank case once it's all apart, just as if you had peeled it apart like a beer mat. You'll probably find someone "glued" the gasket in place with instant gasket several years ago!
Flyboy
Sticky gasket
Tue Sep 25, 2007 4:45 pm » Post: #13 » Download Post
Hi Andy,
yea that was the case, the gasket was definetely glued as well. Somebody was paranoid! I been scraping it off both ends with a putty knife using gasket remover. Slowing me down a little, but I'm not in a big hurry.
Thanks again folks,
Ken
mach1
Wed Sep 26, 2007 4:14 pm » Post: #14 » Download Post
Hey it's not everyday we get an english lesson 'thrown in',we'll all be called cohorts before long. Laughing
Wed Sep 26, 2007 5:28 pm » Post: #15 » Download Post
Well, we don't want the Forum sliding the way of the lower class marques, do we?! Laughing
