Will caustic soda work to clear the chambers of built-up carbon? If I were to pour some down there and slosh it around will I be met with disaster or a sparklingly carbon-less expansion chamber?
worked on mine , make a bung and plug one end up , leave overnight for the caustic to work , make sure its sodium hydroxide thats the strongest caustic soda , the ones you see in home stores are nothing more than oven cleaner
What exactly is caustic soda and where does one get it? _________________ james
MC21 Rothmans
RS250
RC31
CRF250X
748R
Porsche (many)
Nope, they are just heavy! They are double-skinned and also have some insulation, all for noise control.
They actually work bloody well (only MC18 and MC21), but are bloody heavy! I have a set that have had all the extra skin/padding removed (sounds like an American girl I once knew!) and it makes a big difference. _________________ Andy.
Junk the cans on a 28 for a set of free flowing ones, and grind out the restricting washer in each down-pipe. Makes a big difference. _________________ Andy.
They are so damn heavy ..I thought about losing the restrictor ring and getting carbon cans but I may just set them aside in case someone wants the bike stock. Id much rather see polished stainless chambers and carbon cans that weigh half the stockers.
