flush crankcase
jonny
Guest
flush crankcase
Sat Dec 11, 2004 8:50 pm » Post: #1 » Download Post
How do you flush the crankcase? what chemical should be used? It looks like I have some debris in my crankcase and I need to flush it out. Haven't found out where it came from yet.
jeff350lc
Sun Dec 12, 2004 8:49 am » Post: #2 » Download Post
i would strip the engine down and check everything. then clean it all up with petrol. take a good look at the crank, nsr wayne had a thrust washer break up, and it totaled this mc18 motor. Sad make sure you find the problem and clean out all the debris before running the engine again.
salopbike
1989 Honda NSR250 MC18
Sun Dec 12, 2004 2:57 pm » Post: #3 » Download Post
yeh i will second that it onlt takes a tiny piece to total those nicasil bores i have a local diesel garage who has a "sonic cleaner" and a hot wash just like a twin tub for engine bits, sounds strange but i have never had bits so clean and the heat makes the bits dry with out any risk of corrosion, so have a word with your local engine reconditioners or the like and i am sure they will oblige, its worth it
"cant you see the no smoking sign, this is a public space" rrrrrrriiiiinnnnngggggg ddddddiiiiinnnnnnggggggg 2 stroke till i die
