Hello All,
Will a set of TA20 carbs (r2j/r4j) fit a r5k (TA21's).
Reason I ask is that I've fu**ed my set of 21's trying to remove a very stubborn air screw and it will make my search a little easier. Obviously swap my jets/needles etc but what about the tps and anything else,
cheers in advance
Benno
There are some subtle internal differences, but make sure you check the jetting and it should be OK.
Externally they are the same. TPS should be OK, as they have an anti-tamper screw and once set at the factory shouldn't need fiddling with unless your name's Stephen and can't help a fiddle!!
You may find R2/R4 carbs run slightly different, so you may not end up with same jetting/needles. _________________ Andy.
