As avgas is difficult to get hold of, maybe expensive, I wonder what the advantages is, using avgas and what it takes to set the bike back to normal tankgas:
Ignition timing ? Change of compression, heads ? jets for sure.
Someone told me its lower octane than tank gas. Is this correct ?? _________________ Poul
MC21SE, KISS box
MC21SP, HRC box, racing loom
u could use shell vpower instead of avgas, shell claim it has a octane rating of 99 RON and i use it in all my bikes as it doesent make much of a difference price wise to normal petrol on a bike. _________________ Honda nc23 CBR400 AERO 1986, 1990 honda NC23 Tri-Arm, 1987VFR400 NC24 Rothmans Rep, NSR250 MC16 1987, CL250s 1983. Moto guzzi zigolo 110cc 1958. Fantic 50cc 1972. Suzuki Cobra Race bike 500cc 2t 1975 , GP125 1975. Triumph T110 1954. BSA Thunderbird 1955. Ariel VB 600 1952, 1990 MuZ 125 etz.
More compression, more advance, leaner jetting = more power Without any of the above its a waste of money and on the street its kind of unpractical. _________________ 1995 A kit TZ 250
1994 Rothmans NSR 300sp SOLD
As Jeremy says, you're wasting money unless you adjust your settings to take advantage of the fuel characteristics. This goes for any fuel, not just avgas.
I used to run my street bike on avgas 100LL, but I was a little worried about the 200 litre drum at my house, so I switched back to pump fuel when it ran out. This meant lower compression, less ignition advance and a richer carb setup. Lost a couple of ponies, and lost that delicious smell, but much easier just to stop at the gas station to fill up.
