Well I finally did receive my bike from the deadbeat seller, just in time for the snow. I think the kicker was the website I threatened to put up if he didn't come through on the deal. Does any one know what the shim on the front wheel should be torqued to? Also, how do you bleed air out of the oil injection system? There is a small nut, I assume that you remove this while the bike is running and look for bubbles?
To be honest all I've every done with bleeding the pump on my roadbike is just use a couple of pints of premix (from the race bike mix) for the first few minutes, when the pump starts working it makes the mix a bit oil heavy but as long as you don't hold in wide open for 5 minutes its fine (well mine always has been).
Bleeding the pump properly is talked about here, paragraphs six and onwards. _________________ Please do not PM me technical questions, if you can't find it on the Forum start a thread
CoolHand wrote:Any ideas on the torque spec for the nut on the end of the front wheel spindle?
Just a decent push with the good old torque wrist for me but the real figure is 6kg/m or 43.3 ft/lbs.
It may well be hidden away on some near inaccessable page in this html maze however it's all here anywaywarning, blasphemous off Forum link. _________________ Please do not PM me technical questions, if you can't find it on the Forum start a thread
