MC21 seat units/subframes
barryj
Sun Dec 30, 2007 10:17 am » Post: #1 » Download Post
Hi
Can someone tell me if the subframes are different on an MC21 if it has a single seat unit or a dual seat unit.
Thanks
Sun Dec 30, 2007 10:47 am » Post: #2 » Download Post
If you remove the OE rear seat pad the subframe stays the same. The bike is a single seater then with a stock shape.
If you fit a later single seat unit from Tyga you need their subframe.
barryj
Sun Dec 30, 2007 2:18 pm » Post: #3 » Download Post
Thanks Stephen, how about the OE single seat unit? does that have a different subframe?
Thanks again.
Sun Dec 30, 2007 2:27 pm » Post: #4 » Download Post
There isnt an OE single seat unit. They all come with a rear pad that is removable (mc21-28 that is) to make it into a single seater.
The only time you need to alter the subframe on any of them is if you fit aftermarket "rs" style bodywork.
barryj
Sun Dec 30, 2007 2:51 pm » Post: #5 » Download Post
aaaaaahhhhhhh ok, at the risk of awakening the e-bay bodywork arguments! does anyone know if this single seat unit is designed for a normal subframe?
http://tinyurl.com/2clzmz
Sun Dec 30, 2007 3:22 pm » Post: #6 » Download Post
That looks like a copy of a stock '28 seat unit so should fit the stock sub frame fine.
