that shim is way too far down the needle. Adding a shim that sits all the way up to the stopping plate (pushing the needle up what ever the height of the shim is), but that pulls the needle way to far up. _________________ Charles Gallant
I only had it down the needle to make it easy to see, it goes all the way up.
Guess I should mention it's a 28. I don't think anyone has been in there before, all the screws where unmarked. It's got another shim in there now, test riding it soon.
Bloody hell Charles, that '28 would need to have been running no base gaskets, no head gaskets, a bit skimmed off the heads, and neat Shuttle fuel with a dash of Halfords octane booster for the needle to have been that rich! _________________ Andy.
There is a washer in the picture of what is presumably the carbs pre installation of the HRC jetkit in the HRC mc28 manual;
click for a bigger pic.
If no one has been in there you'd be very lucky if stock jetting was spot on for a modded setup, it might be OK, it might not, it might ride alright, it may not detonate into the middle of next week (or it maybe will) but it almost certainly won't be spot on. _________________ Please do not PM me technical questions, if you can't find it on the Forum start a thread
