I just got round to looking at my new front magtek and discovered that there are no threads in the holes for fixing disc I can't believe Honda forgot to thread them
Any thoughts on this anyone
cheers Rob
Hopefully this is a joke, a Magtek uses a long bolt that passes right through the wheel. _________________ Please do not PM me technical questions, if you can't find it on the Forum start a thread
you can't bolt into the mag alloy, so the disc bolts go all the way through the hub and pull the discs together into the wheel. You will need to get the corrects bolts and nuts from Honda. _________________ NSR300R - Why did i ever have a 250...
The disk bolts on my RS250 Magtek wheel bolt straight into the hub, but my NSR250 Magteks bolt through the hub.......not sure what to make of that? Apart from perhaps I have to many wheels
I bought the correct bolts & nuts for the magtek wheels I`ve got.
Can`t see any reason why you couldn`t tap & fit helicoils to allow you to fit ordinary bolts to hold the discs on. The helicoil inserts are a lot harder wearing than the alloy of the wheels.
The part no.s for the correct nuts & bolts are on the parts manual on this site.
A proper RS magtek has its disks bolted directly onto the wheel. You have to be very carful with the threads though as they tend to feel like cheese. Like Maxim says the NSR magteks are almost idiot proof for this reason. _________________ If I have to take the carbs off once more...
You arent the first halfwit to fall for this one Rob! I bought a new set of standard disc bolts for mine, I couldnt understand why one disc was held on with studs and nuts while the other was attached with normal bolts........ until I took it to bits!!!
Mind you at least we can comfort ourselves with the fact we both picked up brand new front magteks for peanuts !
By the way thanks for the tip off on that
