mc18 r5k pick up coils
eggy
Sun Jan 27, 2008 6:57 pm » Post: #1 » Download Post
hi all
got myself a mc18 which im restoring, trouble is im getting no spark, i have found one of the pick up coils is knackered. has anyone got a spare set kicking around at the back of their garage if so i would appreciate a call or if you have any info on wheather any other models have a set that will fit my nsr
ta
steve
07919050777
sussex
Mon Jan 28, 2008 10:59 am » Post: #2 » Download Post
You can also use the pick up coils from either a MC21 or '28 but the pick up leads need extending to reach the MC18 connector.
Matt@TYGA
Supporter - Vendor
Supporter - Vendor
Mon Jan 28, 2008 12:17 pm » Post: #3 » Download Post
and you'll need to add the neutral switch lead
howl
Mon Jan 28, 2008 6:00 pm » Post: #4 » Download Post
Hi Are you sure it's the pick up coil ,not just the lead to it thats nackerd ? Also where are you in Sussex ?
Mon Jan 28, 2008 6:40 pm » Post: #5 » Download Post
The lead to it can't effectively be replaced though, so it's a complete assembly replacement required.
eggy
Mon Jan 28, 2008 9:17 pm » Post: #6 » Download Post
thanks for the help guys
hi howl im down in sunny worthing dodging oaps
howl
Sun Feb 03, 2008 7:51 am » Post: #7 » Download Post
Hi Eggy
If you pm me today with a phone number I could pop down to sunny Worthing and have a look, Andy was correct that you can not compleatly replace the cable but can solder on a new one and heat shrink it if there is a bit of original cable showing. I might have a spare set in the garage ,I'll take a look .
howl
Mon Feb 04, 2008 4:43 pm » Post: #8 » Download Post
Hi I have found a set in the garage so if you have a lit garage I could pop down one evening and we could give them a try. Or next Sunday ?
eggy
Mon Feb 04, 2008 10:57 pm » Post: #9 » Download Post
thanks howl
but ive just managed to buy a brand new pair of mc21 pick ups which i will be putting on tomorrow, hopefully that will get me sparking !!!
steve
howl
Tue Feb 05, 2008 6:18 am » Post: #10 » Download Post
Hope you get it sorted,when you have give me a shout and we can go out on a ride as I'm trying to sort out some rides with the local 400Greybike lads.
