dunkenb wrote:don't i need to adjust the gap??????
Adjust?
Ring gap is not variable. At a guess it will be the same if not very similar to the 21. _________________ If you dont like the way that i ride.....Stop trying to keep up!!!!!
You can still adjust the ring gap with a thin oil stone if its to tight which isnt too uncommon on replated bores. _________________ If I have to take the carbs off once more...
