what's the definative answer for how many holes and of what size to drill into my air box lid? every things standard on the bike and the wire splice has been done.
thought i'd better take the carbs apart for a clean and found the main jets are 145(as opposed to 128 standard). and the air box has 4 holes already drilled in it, opened it up to find that the previous owner was using it with out a filter? guessing it's not a good idea not to run it without????? if i put a filter back in will it still be too rich with 145 mains??
You can get Ramair and HRC filter foam that you can then cut to size/shape.
You'd need a lot more than a Mars bar to tempt me! Something in a green bikini and knee-high platform boots would be a good start! _________________ Andy.
does removing the partition from the centre of the air box lid give the same results as drilling holes in the lid or would you still require the holes even if the partitions been removed?
answers on a postcard...... or just add a reply ! lol.
