Can anyone tell me what the proper torque spec is for attaching the exhaust headers to the 2 studs on each cylinder? - this is for a Tyga rather than stock exhaust, if that makes any difference. Thanks. _________________ -Jim
'93 MC21
anyone? someone please save me from myself - when in doubt I usually overtighten! how about 20 ft lb - seem about right? _________________ -Jim
'93 MC21
The cap nut that screws onto the studsis 2.8 kg-m (20.2 ft-lbs).
The torque settings from a stock exhaust VS the way TYGA uses a flange that the TYGA pipes slide onto and use springs shouldn't be that different. The stud and nut are still the same size and being used in the same application, which is what really determines the needed torque settings. _________________ Charles Gallant
