Last nite i was riding my bike at about 130km when it suddenly just died
It is a mc18 and today i checked the engine witch is fine there is gas everything seems to check out could this be something to do with the Rc valves or the Computer? Well thanks and Happy New Year
hopefully yours will get better, hope its not "the year of the broken NSR" for you in china this year _________________ MC21SP - Roth-tax
CBR400 - track
MC21R - sold
MC21SP - sold
We need a lot more information before we can help me old China.
What exactly did you check on the engine?
Compression?
Did you have the heads off?
Checked the battery?
Is there a spark?
Is there fuel in the carbs?
Are the jets blocked?
Does the engine turn over?
Answer that lot and we can get a better picture! _________________ MC21SP Plaything
Battery is fine there is gas getting into the carbs i had the engine looked at by my buddy he said it was fine i do belive he checked compression the bike almost wants to turn over
But there is no spark changed the plugs wires are newer everything seems to be ok but no spark still???
Next thing I'd do is replace (slave in) a new coil to see if that's the problem. Unlikely as both have failed, but it's cheaper to try than the ignition unit.
After that then providing all the wires check out, the last thing will be the PGM I'm afraid. Try TYGA for help in locating a replacement. _________________ MC21SP Plaything
Try popping the flywheel cover off to make sure a pickup coil hasn't vibrated loose, it happened to me.
One of the small Allen screws had dropped out and had been magnetically "sucked" in behind the flywheel. It lodged in between to of the stator coils and burned the stator out, causing IGN failure!
How did the motor stop? Was it a sudden failure, or did performance seem to break down over a (short) period of time? Also, are you positive there is no spark from either plug? The spark can appear very weak when the plug is out of the chamber, but is actually sound!
Thanks guys I am going to replace the coil tomorrow and will check out the coil pickup !! The bike was running alright just a little hesitant in higher gears but it was doing that for awhile! Yeah there is no spark from both. Im not sure were i can find igniton unit here? Any ideas were i could order one? Thanks for the help
Put a 'wanted' on the for sale section of the site. Try Ebay. Email the guys at TYGA.
Or for a laugh, pop along to your Honda dealer and ask them! _________________ MC21SP Plaything
