Need a little help here. My bike is dying when I turn the headlight on. Runs okay with it off but as soon as I turn it on it dies. Seems to me to be some sort of a charging problem. Any way to test the charging system?
I just put a brand new battery in...
I'm running Tyga headlights and tail lights
Has run okay in the past so this seems to have crept up recently
'93 MC 21
Sounds more like a short circuit to me! _________________ MC21SP Plaything
Well, I got a chance to throw a multimeter on it and while it's running the voltage just steadily drops so there isn't a charge getting back to the battery. I have tested the rectifier and it seems to be out although I'm not absolutely sure what the readings should be but there isn't a big difference when switching the leads around in the diode test mode on the multimeter.
Is there a way to test the stator to see if it is working as it should be?
