thanks to andy i now have an MC21 front end comming for my MC16. i,m also going to fit an MC18 swinging arm. what i,d like to know is, should i use a 17 or 18 inch rear wheel. i can find 18,s no problem. even a magtec from salobike, but i cannot find a 17 as yet.
should i use the MC16 or 18 shocker?
'21 shock is too long. I have a feeling either the '16 or '18 shock will work, as may an early (1987-8 RS250, if you want something a bit more special!
Jeff ive just asked about a price of the frame/swinging arm from a mc21,ifs its the right price you can have the frame/swinging arm shock and linkages from my other 18 for a small fee .
Download the plans on the Technical Resources page, and make up some MC18 F3 linkage plates. That will increase the ride-height by 25mm (1" for those Stateside!!) and stiffen the rising-rate.
Andy wrote:'21 shock is too long. I have a feeling either the '16 or '18 shock will work, as may an early (1987-8 RS250, if you want something a bit more special!
Just to add to that.... The RS250 shock will also transplant directly to and from any RG500 strangely enough as I run an RS250 Ohlins on mine although it's quite and experience setting it up on the road...
_________________ These aren't the droids you're looking for.
nsr.wayne wrote:Jeff ive just asked about a price of the frame/swinging arm from a mc21,ifs its the right price you can have the frame/swinging arm shock and linkages from my other 18 for a small fee .
