I am thinking of buying this. Can anybody tell me anything about it? The seller says that it might be an HRC rear shock for an NSR. It's got some measurements:
305mm height adjustment +−10mm upper hole is 12 by 24.5 and the other is 10 by 39
was taken off an MC21 allegedly.
Seller says that it can be recharged by a scuba tank compressor or something ??!!!?!? MAYBE
So ....anybody recognise it? And should I buy it? Do you think it will be much better than the stock?
Admin edited BBCode _________________ MC28 SE -sold-
i have a21sp shock on my bench at home and they look pretty similar, the remote is the same colour but mine doesnt have that little nipple thing on it.
what does he mean "recharged" _________________ MC21SP - Roth-tax
CBR400 - track
MC21R - sold
MC21SP - sold
yup, looks like a 21/28 shock. it looks a little ratty but that can be cleaned
up. the most important thing is that threaded collar on top to give you ride
height adjustability
Well, I've got a spare SP shock floating around at home anyway (same as the SE right?), so I don't want another one of those!
Are there any advantages of the F3 shock other than ride height adjustment? _________________ MC28 SE -sold-
There's another F3 shock on auction at the moment, I can get that one for you if you like, starts at 200 quid, and I doubt the bidding will go above 250, you'll probably get it for 200.
Do you want it? _________________ MC28 SE -sold-
Julian,
the F3 shock has different internal valving, setup for track use like an RS. Combined with the added adjustablity, makes it real nice to have for track use.
I can tell you that just comparing my NSR back to back with my RS when I was at Ebisu last May, I didnt realize how much the NSR rear shock needs work. The RS was rock-solid and stuck well, the NSR rear felt like it was all over the place and unpredictable. _________________ Paul Herr
'88 FZR4/GSXR/YZF Frankenbike
MY BIKE PICS
Why get an old F3 shock when you can get a new ohlins for about 430 pounds?.I have just put a new ohlins onto my NSR cost $1300 NZ.This included them setting it up for the track.
There's another F-3 shock going for 200 GBP, so you can have that one if you want.
OR there's this thing on auction, but I suspect it's going to go for a fair bit:
Whoops!!! Just bid on it. Yikes!!! What am I doing, I can't afford it!! _________________ MC28 SE -sold-
The added bonuses over the stock SP shock are stronger internal damping, a lightweight aluminium body and ride height adjustability. The actual damper valve is the same as an NSR, but there's nothing wrong with that.
The fact that it has a valve in the reservoir means that it's been rebuilt. They came from the factory fully charged and "non-rebuildable".
I have the very same shock on both my NSR300 and NRS250. They work great. I have another in my box upstair, but it's missing the top mounting piece.
The stock NSR SP shock can be rebuil;t to the same spec as the F3, and then recharged with nitrogen in the same manner as the F3 shock shown in the picture by fitting a valve. Just for your info, they're charged at 150psi.
