Flywheel 21/28 ?
Alzazorq
Flywheel 21/28 ?
Sun Jul 13, 2008 8:46 am » Post: #1 » Download Post
Hello guys,
I have 2x flywheels in my garage which I want to put on my for sale section to sell but have no clue to what bike they came off?
1st one looks standard with the following : 037000-2460 5JY DENSO Japan LKZ06
2nd one's pickup point may have been moved but not sure...the two pickup points near the "FT"(the closer to each other points of the four) marks are a lot closer to each other than the 1st flywheel.Other than that they are identical. Markings on the 2nd one : 037000-3321 DENSO Japan LKZ29
I will appreciate it if anyone could help me with this mystery!?
Mario
Sun Jul 13, 2008 9:07 am » Post: #2 » Download Post
I've got (what should be) and mc21 flywheel here 03700-2461.
Alzazorq
Sun Jul 13, 2008 9:30 am » Post: #3 » Download Post
fontyyy wrote:I've got (what should be) and mc21 flywheel here 03700-2461.
Okay, so if yours is a 21 ( which you are not sure about ), then the 1st flywheel might be a 21 ? Can you maybe compare the 21 flywheel you have to the flywheel on your 28? ( If you still have the 28 flywheel on? )
Alzazorq
Mon Jul 14, 2008 5:27 pm » Post: #4 » Download Post
No one ?
NSR250MC28SE
1994 Honda NSR250MC28SE
Mon Jul 14, 2008 8:18 pm » Post: #5 » Download Post
I have a MC28 Flywheel i have taken off my MC28 a couple of weeks back to do the MC21 swop.
i will look at for you in the morning and post the numbers.
Cheers Rob
Alzazorq
Tue Jul 15, 2008 5:08 am » Post: #6 » Download Post
Thanks so much Rob, will you also compare the pickup points on the two flywheels please?
Mario
Alzazorq
Wed Jul 16, 2008 5:17 am » Post: #7 » Download Post
Any news on the flywheel Rob?
Mon Jul 28, 2008 8:21 pm » Post: #8 » Download Post
Right then
mc21 037000-2641
mc28 037000-3321
The 21 flywheel obviously has it's pickup points the same distance apart as a 28 but thery're about 2mm further clockwise around the wheel as it's mounted.
Alzazorq
Tue Jul 29, 2008 5:39 am » Post: #9 » Download Post
Thanks a million fonty, so the 2nd one of my flywheels has definitely been changed(MC28) and the 1st one is a MC21.
Will put it up for sale soon! What you recon they go for?
Cheers Cool
Tue Jul 29, 2008 6:10 am » Post: #10 » Download Post
'21 ones are worth something to '28 owners (not much, mine was US $25), '28 ones are worth nothing to anyone unless they've got a '28 without a flywheel.
