Some of you may have seen my post in the classifed section.
I have a 1993 MC21 SP w/ 1992 Rothmans fairings (not China bodywork)
I have been trying to put her back together. The pervious owner took it apart after last race season and put a top end in the engine.
So when I got the bike the bodywork was removed and the wiring harness also removed. I got a subframe as the other one was not included with the bike.
What I need are pics of the rear section with the fairings removed to help me get an idea of the general layout of the PGM III and wiring up from the engine and transmission side cover.
Also the Thermostat housing on the front of the bike does not look to be connected right either.
Thanks in advance for any ideas _________________ 1993 MC21 SP
This is the only pic I have to hand. NMot much use, but you can see that the PGM sits at the very back ofthe subframe, with the wiring loom running up the left seat frame rail. Ignore the box and wires dangling, that's the HRC box half way through fitting...
_________________ MC21SP Plaything
