Looking good bud. Does the seat unit bolt to the subframe anywhere, and are you going to use the airbox to fill the gap under the tank? Also, have you got adapter brackets for the front calipers.? If not, Mr Kimber could knock you some up. Can't wait to see it finished with a paint job. _________________ Warning:
This post may contain traces of peanut!
yes nigels got a list of things to do as you said caliper brackets,seat brackets,battery box,front fairing mount..... and yes the airbox fills the gap it joins up to underneath tank and when sealed is fully preasurised i will try and bung it on tomorow _________________ ive seen more tarts than mr kipling
i can imagine mate but the pound int to bad and i can honestly say the quality of both companies carbon is excelent _________________ ive seen more tarts than mr kipling
