Oil pump failures. why?
NSR-LOVER
Sat Jul 26, 2008 9:25 pm » Post: #1 » Download Post
Hi everybody!
as mentioned before my oil pump had a problem thats why i'm running premix...
What are the reasons that make the oil pump failure?
except the obvious but rare as you say problem with the sprocket...
Could a damaged pgm make the oil pump not working properly?
I'm asking this because with the wires and all that it seems they have a connection but why?
Sat Jul 26, 2008 9:57 pm » Post: #2 » Download Post
Never personally seen a pump fail.
NSR-LOVER
Sun Jul 27, 2008 7:30 pm » Post: #3 » Download Post
That doesn't mean it can't happen...
mine was not flowing and anybody could figure it out
Stupid me i should video everything so you could see what i mean.
I know 2-3 NSR's here in greece having the same problem.
now i am waiting some jets to adjust the carburation because of the premix and the wiresplice/open airbox mods i want to do.
Andy, thanks for the update in the carburation section it will help...
Jet kits coming??
Sun Jul 27, 2008 7:47 pm » Post: #4 » Download Post
No, it doesn't mean it can't happen, but the only "fault" I've ever personally seen or heard of, is the oil seal slipping down the shaft allowing the 2T to drain into the gearbox!
I would suspect the most likely cause of a failure to be contaminated oil blocking the filter in the bottom of the oil tank, but it's difficult to comment on when failure is so uncommon.
The flow at idle is extremely low. I don't know the figures off-hand (they may be in the manual), but I suspect visually it would appear as if the pump is broken; the feed is that slow.
banshee
1996 Honda NSR250MC28SE
Sun Jul 27, 2008 7:59 pm » Post: #5 » Download Post
yes andy you are right as mine has just dropped all its 2t oil int the gearbox
now looking at the online parts breakdown it isnt clear which is the seal???
do you know the part n.o.
cheers phil...
NSR-LOVER
Sun Jul 27, 2008 8:08 pm » Post: #6 » Download Post
Everything you say is right i havent removed it so nobody knows...
But we checked it and in high rpm's with the mechanism wide open and only a tiny little oil ball (dont know how else to describe it) . I will buy one thought and strip it down,chek it, untill it is perfect and then install it cause 3% oil is lots of money...
maybe a good idea is to have the oil pump in situ and add a very small amount of oil in the gas tank.
fenton
1990 Honda NSR250 MC21
Sun Jul 27, 2008 8:14 pm » Post: #7 » Download Post
pressed the wrong button Embarassed
fenton
Sun Jul 27, 2008 8:15 pm » Post: #8 » Download Post
NSR-LOVER wrote:.
maybe you are running bad oil like andy said Rolling Eyes i have been here on the forum for a good few years and this is the first time i know off that a pump has failed
NSR-LOVER
Sun Jul 27, 2008 8:16 pm » Post: #9 » Download Post
unbelievable!!!
Now everything is clear!!!
After the rebuilt i opened the plastic gray bolt to check the transmission oil and excessive oil came out! lots of it!
And i didnt knew why....
So i got the seizure because of this...
Sun Jul 27, 2008 9:35 pm » Post: #10 » Download Post
cheers phil...
The oil seal isn't available from Honda. Apparently it's the same size as some SeaDoo part or something, but I've never had to replace one, so don't know off hand!
I've suggested in the past to clean the oil seal and its housing thoroughly with white spirit or similar, and then smear a very small amount of RTV sealant on the seal to act as a bonding agent to hold the seal in place. It seems to work.
NSR-LOVER
Sun Jul 27, 2008 9:55 pm » Post: #11 » Download Post
Then the problem seems it can be solved...
So, as you say we just have to make this seal stick there!
fenton
Mon Jul 28, 2008 8:14 am » Post: #12 » Download Post
heres the oil seal anyone ever found were to buy them i have had a good look using the part number on the seal with no luck to date Confused
RichG
Mon Jul 28, 2008 9:53 am » Post: #13 » Download Post
I asked my Dad to contact their company's seal supplier.
They can supply this seal, that sized seal comes in 2 slightly different elastomer rubber types, signified by the colour. (apparently G usually refers to blue, as opposed to black). Phil or Fenton, just reconfirm what colour the seal is, Fent's pic looks black? These seals are now all rubber, rather than metal - rubber, but that won't make any difference. The supplier said they are on the shelf, cost approx. £3.00 they think.
Phil, I'm overseas later today for 2.5 weeks. You can call my Dad (John) directly at JP Plant Hire on 01977 683324, if you want him to get you some seals before I get back.
Rich
fenton
Mon Jul 28, 2008 10:28 am » Post: #14 » Download Post
Nice one rich Very Happy yes its black mate
the same seal is on the engine in a manco go kart. not sure what model
80049 : OIL SEAL - 9.5X16X4
Manco Part Number: 80049
Manco Part Decription: OIL SEAL - 9.5X16X4
Manco Part Category: ATV PARTS
banshee
Mon Jul 28, 2008 12:26 pm » Post: #15 » Download Post
thanks rich but after further inspection and also what andy said the seal on my bike has not failed but just slid down the shaft and out of the pump casing so now i have cleaned everything up i have glued it in place with some silicone sealer
i had the o`rings in stock so ill give it a test and keep an eye on tthe gearbox level!!!!!
