Andy,
Do you know if the discs you suggesst ( NC30 are the same offset as the NSR?) I am fitting UDS forks and have found method of using NSR front wheel but forks were designed for 300mm discs , I need discs with same "offset" as NSR.
BR
Dave. _________________ MC28, Honda RC30,
BMW GS1200.
1000cc Bonnie.
NC30 are what I originally fitted to my MC21 with NF5 RWU forks, then with my NF5 USD forks, and then with my Magtek with NF5 USD forks before I fitted the cast iron NX5 discs... Honda are like that!
HRC aren't like that though! Although the offset of my cast iron discs are the same, the diameter is 297mm and will only work with HRC calipers! Good job I have a couple of pairs then! _________________ Andy.
